POSTS and PRODUCTS OPTIONS
Here, with products I can’t the way to dissable breadcrumps, categories and tags.
In my panel, I never allow to show this.
I’d like a clear website without all this info.
https://www.escueladesurfonthesea.com/reserva/surf-camping-septiembre-quincena-1/
Also appear 2 times the word Description (Descripción in spanish) I want it only one time.
Hope you can help with these problems.
Thank you in advance.
Cheers!
Mario
Unfortunately, our theme do not have an option to remove these elements from woocomerce page, but you can use a css to remove them https://i.imgur.com/BC0jc5g.png -> https://i.imgur.com/y7xJWsu.png
.single-product .entry-crumbs, .single-product .posted_in, .single-product .tagged_as, .single-product #tab-title-description
display: none;
The code need to be set in theme panel> custom code> custom css.
Hope this will help you!
