Posts and related posts tied to it?
Not sure if I can explain this clearly.
What I want to have happen is make a post, create a layout style, for the posts that are for the monthly issues we produce in print.
Then, if I need to use a tag, say August 2020, I can tag the articles there are in the paper online.
Can I create a layout and then add related posts via tag to that layout?
Has anyone done this?
Would a template work?
Or would I have to have a new template per each month?
Hi Chris Baird,
The tags will work as categories, you create them and assign to posts after that when you select the tag it will be open the tags page where will be display all the post that have the selected tag. Also you can use a cloud template for tag template.
Hope this will help you!
Is there a way to set a featured image or an image that will be the one that is shown on social media when a tag category is shared?
Hi Chris Baird, yes, using Yoast SEO you can set a image for posts/pages .. that do not have an image set -> https://i.imgur.com/p06Ssh1.png
