I have a new installation of newspaper, so I switched from another theme. If I try to create a new post, there is no option where I can choose to use a page builder (e.g. the tagDiv composer). However for a new page this option is available. (composer is also installed of course) So there is only the text editor.
What can I do to make the visual builder work for posts (for new posts)?
Is there a chance to edit posts from an previous wordpress theme? Or is it better to create the posts entirely new?
Kind regards,
Andreas
tagDiv Composer is a page and cloud builder, it can be used only for pages and cloud templates, therefore you can use it on a single post template from tagDiv cloud library to adjust the layout, but not to write the post content, for this, you need to use the WordPress editor.
You can edit the page with TD Composer in WordPress->Pages => https://www.screencast.com/t/AMOjYCA7Q7p, or in front side.
