Posts are not published in categories
Hi. I have a problem. My posts are published correctly, they appear on the cover, but they do not appear in the category that I assign.
Well, except in one category, they are published there. I have checked that all the settings of the categories are the same, so I don’t know where the problem is.
Can you help me?
If you are using a pro demo, pleas check with tagDiv Composer to make sure that you do not have set some offsets on the posts loop -> https://i.imgur.com/aJ7qNBW.png -> https://i.imgur.com/r1Cj3Ga.jpg
If there is still a problem or this is not what you mean, please provide some more details an some screenshots.
Thank you. I have checked and that is not the problem. In the only category in which the posts are published (although the most recent ones are not published, however) there are the same parameters that you show me in your capture, but they are also the same in the categories in which they are not published. I send you two captures.
http://www.areabesos.com/images/Captura-actualitat.jpg
http://www.areabesos.com/images/Captura-societat.jpg
Unfortunately I can not see these screenshots -> https://i.imgur.com/Wc4Lwvy.png please provide ma a link where i can inspect this problem.
Sorry, try again in the same links, I had deleted the captures by accident
Please make a test, add a new flex block and set the filter on it to see if the posts from that category are displaying -> https://tagdiv.com/tagdiv-composer-page-builder-basics/ if is working then you can use the right click to copy the style form that block to your block
Let me know the results!
