in the mobile version on smartphones the posts and pages are not shown on http://www.cadzand-online.de…Only to see is the burger menu and the footer – no content between.
Thansk for the support again
Michael
I checked the website and it looks that for mobile version you are using the mobile theme plugin, and this is different from responsive version, also, for pages it will be need to set a content in mobile editor –
If you want to have the same content on mobile as on desktop, then use the mobile theme only for amp, or disable the plugin – https://tagdiv.com/mobile-theme-get-mobile-ready-with-newsmag-theme/
I have deactivated the Mobile Theme-Plugin – the content is now presented, fine – but the burger menue is not working… so there is no navigation on smartphones possible…
Thanks,
Michael
Hi Calin,
now it`s working – I deactivated al plugins without tagdiv. Mobile version was okay and the problemms with the gallery are also soleved. I only actived additionallly the WP Bakery Page Builder, Iframe and All-in-One Event Calendar by Time.ly. An I updated Newspaper Theme đ
Thanks, with best regards
Michael
