I designed my site using the Tagdiv blocks. It allows for several posts to be loaded on one page and then the user can click on them to get to the post they are interested in. I recently noticed that the links are no longer working correctly on some of the pages. I tried to delete the block, save and then re-add the block but it is not working. I checked the link and it brings the user back to the home page of my site. Can you please provide a fix for this issue.
Hello jmedina0107,
Ensure that you are using the latest version of the theme, installed via FTP way, remove all of the untested plugins, clear all the caches and check the results. If the problem is still there, try to make a new clean install from scratch to another subdomain via FTP way and check the results. Also, if the problem is still there, please provide your website URL so I can take a closer look at it.
