On a specific page of my new website, I got a Posts Loop 2 that keeps loading the same posts over and over.
Here it is : https://tribu.bequiet.me/actualites/
I tried to change the pagination type (infinite load, etc.) but they all have that issue.
There’s just “Normal numbered” that behaves differently (which is another issue).
On that one, only the 1st page works as intended. As soon as I load another page, it leads to an empty page with only the header navigation and footer on it.
Note that it’s a page a created from scratch and not a template or something, and that it’s filtered to display all the posts no matter the category or anything (so yes, there’s is plenty of posts to display other than those that are loaded again and again)
On the other hand, all the template pages I got that uses the Posts Loop 2 work fine.
Those don’t have neither the 1st (same posts loading) or 2nd (normal numbered loading nothing on other pages) issues.
Here’s an example of working template page (it’s the 1st category archive page) : https://tribu.bequiet.me/category/economie-finance/
Any idea what is wrong with that loop ?
Note that everything is up to date on the website (plugins, theme, WP,…).
Thanks in advance,
Simon
Please check in the posts loop element settings if you have any offset and let the offset field empty with no space, no value and see the results.
Please try not to reply multiple times in the topic if possible, this will only delay our response. Replying multiple times will refresh the topic date and move it to the back of the line, we answer from oldest to newest.
