Posts Loop 2 showing limited posts on category templates
Environment
Newspaper 12.7.1 (fix claimed in 12.6.9)
WP 6.4.2, PHP 8.x
Permalinks: “/%category%/”
All caching/minification plugins disabled; server cache purged
Issue
On two independent sites, Posts Loop 2 still renders only a handful of posts on the front end—even though the Composer preview shows the full list.
Workaround
Switching to the Flex Loop Builder block surfaces all posts correctly.
Expected
Posts Loop 2 on category templates should output all posts exactly as shown in the preview.
Thanks for looking into restoring full loop support!
Could you please contact us via email, create a staging environment, and provide access to it? I just tested it and, for me, the posts loop 2 is working correctly, so I believe there are some settings or a specific situation that is causing this issue.
