I want to filter ‘Posts loop’ and ‘Posts loop 2’ block for category. It’s possible?
Unfortunately ‘Posts loop’ and ‘Posts loop 2’ can not be filter like the standard blocks, sorry!
I think that the only way that you can change this will be to make some changes in theme files, and change the current filter ( “latest” ).
Those files are in wp-content/plugins/td-cloud-library/modules/tdb_module_loop.php
https://www.screencast.com/t/cXjtYGU6fm9H
The Loop -> https://codex.wordpress.org/The_Loop
