Posts Loop Element -> Category Filter
Dear Support,
is it possible to Filter the “Posts-Loop” Element after exclusive Categories?
Greetings
Hello !
Unfortunately not. The post loop element will auto-render the posts from the category that it was inserted in. You can use Flex Blocks instead which have a more customization range.
