I’m using the Default Pro demo.
Using Posts Loop 2 module on the Default template homepage, with “Normal numbered” pagination …but each page (2-246) is completely blank.
I want to use Normal pagination; not the ajax arrows.
When I edit the Home page on the backend, and set the template as Pagebuilder + latest articles + pagination, the pagination works, but I am unable to customize the built-in Posts Loop 2 from the Pagebuilder on the front end.
How can I get either the Posts Loop 2 module normal pagination to work, or customize the Posts Loop 2 built-in area?
Will provide login details if you need.
Drew
Please check this option is checked on the row => https://prnt.sc/10djsv9 if yes please disable it and see if the problem persists.
