Posts loop post view count
Hey there,
Is it possible to add the post view count to an element like the posts loop?
If yes – how?
Best regards!
Unfortunately, the posts loop shortcode doesn’t have this option to show the post views.
A workaround could be to use the Module Views shortcode in a Module template and display the custom module using the flex block builder shortcode in your homepage for example.
Documentation here: https://forum.tagdiv.com/modules-builder-newspaper-theme/
