Posts Loop Repeating posts
Hi.
I’m using posts loop in the Newspaper template, but if i set “Limit post number=X ” the section repeats the same posts every X posts.
Screenshot-2020-09-14-at-18-36-23
I’ve checked all the available options with no success.
Can you please help.
Best Regards
Daniela (LadoF)
  • This topic was modified 6 years by ladof.
Hi ladof,
What you can do is to use the options from here -> https://i.imgur.com/SKx2eM1.png
Also please note that we recommend to use only one post loop per page/template if you want to use more we recommend to use flex blocks -> https://i.imgur.com/3vdxGSB.png
Also on pages you can use the option for unique articles -> https://forum.tagdiv.com/unique-articles/
