I’m trying to create a new section in my blog using Posts Loop module.
Unfortunately the different lenght of posts title makes every single blocks of different size. I try my best with settings but I can’t set an unique size, can you help me?
this is a screenshots about my issue https://ibb.co/xLnpcS3
If you look to the Posts Loop settings, you can find here an option: https://www.screencast.com/t/UnrslNGGibTH
Set a value to the Title length which is suitable for your needs.
Hi!
Thank you for your reply but I already try this option.
This doesn’t work for me beacuse I can set eg. “5” intitle length and I put in the first title 5 words where every word is composed 5 letters each one and in the second title 5 words where every word is composed by 10 letters so the block will not be of the same size.
Please make sure you have the latest update of the theme and plugins also.
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
