Posts not showing in categorys
Hello People,
I have the issue, that my posts won´t show up in the categorys. I tried to use a default WordPress theme and they showed up again, so i tried to reinstall the Newsmag theme and the problem still persists. I really hope you can help me.
Thank you in advance!
Hi Asdria, can you please provide a link to your website where we can inspect this situation.
Sorry the issue got resolved. The thread can be closed.
Hello, how did you resolve the problems that the post per category are not showing up?
Hi wjs@diema.at,
I just checked your website https://www.wirtschaftsanwaelte.at/ and it looks that you have set a redirect to homepage when you access the categories.
Sometimes when the posts are not display in the category that is assigned it can be from an extra plugin that it is used. Please make a test using only tagDiv plugins and see if the problem persist. In case that the problem is no longer there, then enable the plugins one by one and check the situation until you find the plugin that is interfering with the theme.
following plugin kills it: Connections Business Directory
https://connections-pro.com/
any idea what i could do? i need the directory
solution: i changed the category slug in the advanced section of the plugin – now it works. thanks for your support
I’m glad that you manage to find a solution!
Have a grate day!
