Posts not showing in subcategories
Hello Sir/Madam
posts not showing for the subcatogireis.
for example if ABC is a post.
“A” is main category of ABC post
“B” is subcategory of :A”
when i will open the post and click on the “B”. I find no post there. “ABC” post should be there but i am unable to see that,, when i click “A” then “ABC” shown up… why the subcategories are not showing.
i am facing this experience in LifeStyle Pro template
check attachment
1
2
3
Please edit the page with TagDiv Composer and please check the element’s settings. Let the offset field empty with no space, no value, then the posts will display. Check also the filter.
Hello, Thank you so much, all the posts are now showing 🙂
