Posts not showing right in social media
I’ve updated to Newspaper 9, and after that I’m not able to share a post correctly on Facebook. The featured image doesn’t show, and there’s no excerpt text. Seems like it only wants to post the front page, and not the entire permalink.
This is what the Sharing Debugger says:
Warnings That Should Be Fixed
Inferred Property
The ‘og:image’ property should be explicitly provided, even if a value can be inferred from other tags.
Missing Properties
The following required properties are missing: og:url, og:type, og:title, og:image, og:description, fb:app_id
Curl Error
Curl error: 7 (COULDNT_CONNECT)
I figured it out via the Yoast SEO plugin.
I have Yoast installed and set up and I am still getting this message. Did you do anything in particular in Yoast to correct the OG problem?
Hello @Rhonda !
Please provide a link to your website so we can take a look.
