Posts on mobile and sidebar
Hello
Please refer to the video.
There is no problem with widget in configuring in the sidebar.
however when the posts are visited by clicking post url, the posts are not able to display widget.
Now magine situation where the post was found in web search or if i have forwarded the url to someone by email or whatsapp.
Now for example if person lands on a post straightaway, using a post url, they cannot view the post in their own language on mobile posts. however the pages are able to display translator.
I am querrying if the individual posts when viewed in mobile can load the widget just like the way it is displayed on PC Tab and web version.
Currently i have tried everything.
please suggest if there is a way to this.
The link to video.
https://app.screencast.com/511O49gQ6LZ1K
The widget is not displayed on mobile because you added the element in the header mobile, and this section is applied only to the desktop and tablet versions. For mobile, you need to select the viewport for the phone to add in the Mobile menu -> https://i.imgur.com/8Cntjoz.png
Also, I noticed that you use a standard template, and for those, the elements from the sidebar are loaded to the bottom of the post -> https://i.imgur.com/lSRmRMS.png if you want to have the widget first, you need to use a cloud template.
Thanks for your help. i have managed to get the translations on the posts. so lets consider this partially resolved.
now please guide me how to get it on the pages.
the translation widget is displayed on the home page but not on the other pages.
i am not using a page template or a home page template.
also let me know how i can get the widget on all pages.
also let me know how can seperate pages are to be setup via templates.
I recommend setting the widget in the header; in this way, the widget will be on all pages that have the header template.
Can you please provide more details about what you mean by ” how can separate pages are to be set up via templates?”?
My aim was to create a unique home page.
The home page cloud template cannot be used because it may run into speed issues. [As per one of your or your colleague replied]That’s ok .
Therefore what’s the best way to achieve the following using cloud templates?
A unique home page
Unique about Us page
There are about 12 unique pages that need seperate designs.
Unique category pages(s)
For example a unique category page for a tech category and a different for entertainment.
That’s what I was aiming for.
So, for the pages, you can add new page like here and create it with tagdiv Composer -> https://i.imgur.com/7DocBaI.png -> https://i.imgur.com/smVRXlX.png
For category, you can assign the template for each category in Theme Panel -> Categories https://i.imgur.com/73rDrdL.png
