Why is it that on mobile (both on the mobile theme and the responsive) – the the post does not fit?
It’s difficult for our readers. The posts always floats around to the right shows like a blank page – it is not fitted to the screen.
At first I was using the responsive mobile, switched to the mobile theme and it is still same.
Please resolve this
Hello eyesandvoice,
I have checked your website in mobile mode and I haven’t noticed any problems with your posts, as you can see here -> http://screencast.com/t/kHjtxylj5Y2y and everything seems to work as properly. Also, to achieve best results with our theme, please try to use only the plugins that come bundled with our theme and try to disable others that are not tested with the theme to rule out the conflicting plugins.
So, if you need more assistance in this regard, please provide some useful screenshots where I can identify your problem if it still exists.
Thanks for your message!
Thanks I managed to figure what the problem was before your reply. It’s my style of writing which I have changed on the post on your screen shot.
