Posts Repeating On Homepage When Using Load More Button
Hey,
On my HomePage (http://dev2021.defense-92.fr/dev21/), the load more button is repeating the posts that are already showed…
The filter for the Blok 14 is Category : All Categories and Sort Order: lastest.
Any clue?
thanks!
i have the same problem.. and is much more wide than this! … pages on category pages too..even categor sometime are messed up….
The issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
Hey, already done.
I put the parent theme back & just left activated those plugins: tagDiv cloud librairy, tagDiv Composer and TagDiv Standard Pack.
But it didn’t resolve the issue…
Any help?
thanks!
Hello !
We need to take a look and see what happened there.
Our team will take a look !
Hey, I just sent to you the email! Could you check it please?
thanks!
