Posts Repeating On Homepage When Using Load More Button
http://45.32.152.57/
this is the ip of the website.
On homepage I am facing weird problem. After pressing the “load more” button in sections, the posts are repeating. I have enabled unique articles.
This happens when you have a random sorting order or you have the same sorting on multiple posts. The unique articles will not work with pagination simple/load more or others. Please use a different sorting order for your blocks if you use pagination: https://forum.tagdiv.com/block-settings-guide/
