You can add the text for Single Post Subtitle in post editor -> https://i.imgur.com/m2altqh.png and you can add the element in post from tagDiv Composer -> https://imgur.com/2cNrcZ4
Hi there!
One would not normally ask a question if he has not tried out something. I am aware of the location of where to addsubtitle within the post-editor. My query is that the subtitle does not show up whether for panel, default or single post template. When you emphasise Singl post template, do you mean subtitle does work for other posts templates?
For the avoidance of doubt, I have changed the posts to a single post template and even a new post based on the single post template and added the subtitle, yet the subtitle does not show under the main title of the post. See screenshot
Please, note that I am creating a post under the role of an Editor, not an Administrator so the other option of using the Tag Div composer to edit the post and add subtitle is not available to me. If this option is the only way it means other Editors cannot simply add subtitles to their posts?
So my issue is not resolved.
This reply was modified 4 years by
Ibalex.
I think that you are referring to this one https://i.imgur.com/D0jRpRj.png our theme does not has an option to display the subtitle on blocks, this can be done with some custom changes or a better approach is to use the custom label and set the same text like the one from the subtitle -> https://i.imgur.com/mDEjkDe.png the results will be -> https://i.imgur.com/pYBWKri.jpg (you can style the layout).
Sorry, I am not referring to the first screenshot you shared. I am referring to this
I am not referring to subtitles for blocks. I am simply referring to a subtitle that appears under the main news title.
You are not answering my questions fully. Is the tagDiv Composer post editor not available to a person working as an editor instead of an Administrator? For instance, I was able to add subtitle in TagDiv Composer editor but under the role of an Editor, I do not have access to the TagDiv Composer Editing environment. Question is how does an Editor add subtitle then? This is not about blocks, please. It is about a subtitle under a major news title. See the screenshot
it says “The text will appear under the title.” Thank you.
Ibalex.
I’m sorry for the misunderstanding. I did several investigations and it seems that by mistake the developers reversed their rights, meaning that as an author you can add subtitles in the post and as an editor you can’t. So you can ask the admin to add the element in the post.
Thank you for your understating!
In fact, I should mention that the tagDiv Composer is not always available I am not sure why. I read somewhere that tagDiv works with cloud templates. Not sure of the implication of this for my post that I created by myself. I cannot edit them using tagDiv because that editor is almost always not available even as Editor and Admin of the site. The tagDiv appears only available when editing the home page. It disappears when I navigate away from the homepage. See screenshot
of a single post template without tagDiv editing feature
As I said above, there is an issue with editing rights. Now for the editor role, editing with tagDiv composer will only be available on the page, not on cloud templates. So in order to have access to all the options, you need to have the role of administrator.
