Posts with pagination not working and lightbox query
Hi there,
Just started working on the newspaper and simply cant get in post pagination to work?
I am adding <!–nextpage–> to the text section and it simply removes the line break rather than adds a second page.
Any ideas? Am I missing something?
Additionally I notice there is lightbox facility on featured images (I have turned this off btw as un needed) however do you not have lightbox capability for general in post images it would seem counter productive to add a 2nd plugin to do exactly the same job as a plugin (or code) that is already active on the theme?
Many Thanks in advance
Please make sure that you use the <!–nextpage–> in text editor, not visual editor.
About lightbox, a simple solution is to disable our lightbox and use a plugin that will work with all images from post automatic.
Hi Marius,
I mentioned in my op that I was entering <!–nextpage–> in the text editor and it still does not work?
Any thoughts?
Please can you give us access to your WP to take a look. Also what else you can try is to disable some plugins, empty cache(if you use some cache plugins) and see if work.
Send via email at contact@tagdiv.com
Marius
My servers went down the day I sent over those details (Typical eh?)
Anyway in the meantime I have found using <!--nextpage--> seemed to do the trick thats with two -- <!--nextpage--> as opposed to one - <!-nextpage->
Can you confirm if this is correct? and safe?
Useful for anyone else with the same issue if its the correct way?
Cheers
  • This reply was modified 12 years by AccountKiller. Reason: mistake in code
UUUppps, sorry i wrote the wrong code the correct one is <!--nextpage-->
Thanks for the eagle eye 😉
