Hi there,
I am using the “Flex Block 1” and try to show all posts that match one child category (3409) and another parent category (3437). The child category is linked to a different parent category.
However, using the option “Posts(cpts) must belong to all terms” does not seem to work with parent categories. It does not show the posts from the corresponding child categories. Attached you can see that even using only the parent category 3437, the number of posts differs depending on if “Posts(cpts) must belong to all terms” is activated or not. (Link to screenshots: https://imgur.com/a/pqNuqiO)
Any ideas on how to display all posts that match one child category (3409) and another parent category (3437), including their child categories? I would also be open to use a different block type if that helps.
Best regards,
Tim
