In the single detail pages, there is Previous and Next posts links are given but they are fetching results according to publish date from any category.
We need category specific posts should appear in previous/next post links.
Please help
Hello @onlineimages!
For the element called Single Post Next Prev, there is a setting which needs to be checked Display posts from the same category.
Hope that helps you!
thank you for your email. where i can find this setting. Please guide.
You can edit the single post template using the tagDiv Composer -> https://i.imgur.com/T0Kwv8R.png -> https://i.imgur.com/2Kv8Cyn.png
Hi Calin,
I am using theme standred template 7. how can i apply that changes.
If you are using standard templates, then the options can be on/off from the theme panel -> https://i.imgur.com/0aV0q3U.png
I need the Previous / Next post Article must From same category on artcile page.Right now it is not coming in this way.
If you check the settings from theme panel, then it should display well. Please provide your website link.
Hello Bettina,
Please see the below link this article showing different articles from differnt category in next & previous section
http://beta.imagesbof.in/2022/02/25/kishore-biyani-future-group/
I’ve tested on my end and for me it’s working well. Please make a test and deactivate ALL plugins except tagDiv ones, also deactivate the cache plugin that you use, and try again.
If the problem persists, then we can take a look at this and investigate why is not working for you. Please contact us via email at contact@tagdiv.com and provide the following:
– admin URL and credentials
– cpanel url and credentials
