Print article – header problem
If I try to print this article to PDF, the header logo disappear and only shows the “ACONTESER” banner. Do you know why?
Did you made modifications on the print css? Check the print css inside the style.css file – http://screencast.com/t/lY1oRHCc See what items are disabled on the page, if possible paste the code here or provide an image with it.
Thank you, Emil G.
I’ve change the CSS to show that banner in the mobile view, so I have to hide it in the @media print.
