hi,
I am using Cloud Template from Gossip pro in my site. Its not showing any image when I want to print a post. Then I checked Newspaper demos site also. I found, images not showing neither on Demo site nor in my site.
Then I tried to fix it by custom CSS as you mentioned here
But its not working also. What to do to show featured image and site logo in print page?
It should work well. Please make sure you use the Single Post Featured Image and not the Single Post BG Featured Image, change the element: https://www.screencast.com/t/lQoN5x6QAiU
CSS here:
@media print{ .tdb-featured-image-bg { display:block;}}
Results here: https://www.screencast.com/t/B7ohxOGj
Then the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
