hi – the font on a mobile on a pro template is incorrect. I don’t use the mobile theme – I just want to be able to change some settings on mobile for a template. The font is too small. How?
To change the fonts for mobile version, please select the viewport on phone and from there you can change the fonts => https://www.screencast.com/t/A7p6KuUVvP -> https://www.screencast.com/t/lKTWSrpQ2Z
Hope this helps you!
