Problem: 1 image uploaded and 10 images on hosting
I have a problem and maybe someone can help me, I read documentation and I know that every module use a cropped image in differents sizes. After 10 years I have a site with 200.000 files… How can I reduce number of images without change layout of newsmag theme pages and reduce modules?
What you can do is to use a regenerate thumb plugin that is deleting the an use thumbs.
Also you can make a test and try to replace the old blocks with the flex block element, this have more options and it can be adjusted after your needs, you can choose the image size too -> https://i.imgur.com/cBHEFuF.png you can check this documentation for Flex block -> https://forum.tagdiv.com/flex-block-settings-guide/
Also make sure that you have enable only the thumbs that you use.
