Look at this link plz!
https://storage.googleapis.com/allrever.com/2018/09/5e520058-image1.jpg
Is that area not the area of module 2 of block 2?
However, 324×235 images are displayed instead of 324×160 images.
Please help me!
P.S My Homepage is https://allrever.com
thank you for the reply.
The theme is that the width of the image to be regenerated is 324×160 and 324×235.
So I changed the 324×235 regeneration to 325×235 using the plugin called “Simple Images Sizes” and started to recognize it properly.
Simple images Size : (https://wordpress.org/plugins/simple-image-sizes/)
I think this is probably because it’s not compatible with the WP-Stateless plugin, which uploads images to the automatically Google Cloud.
WP-Steateless : (https://wordpress.org/plugins/wp-stateless/)
I’ll use it this way, and if I have a big problem, I’ll have to remove the plugin.
Even if there is an option to limit the image regeneration of this theme, it is not a level that can be ignored in regenerating capacity.
If i upload an image, i need 2.5x(Storage space) additional image.
Anyway thanks for checking my site and replies!
