Problem
I, i have this problem.
I need put on the center my header ads.
https://www.pcusb.it/92ef13f4-a7a7-4e70-bac7-a2c50a8cb493/
My website: https://www.pcusb.it
The header ad cannot be positioned in the center position on the header style that you use. Please use header styles 9, 10 or 11 if you need a centered ad.
I’ m sorry, tgis is the problem:
https://www.pcusb.it/1b53109f-8001-47de-82fa-33c44817987f/
Different space on top and bottom on the iPad.
So it happens on an iPad? I could give you a code to add some margin top to the header ad both. I tested with the emulator, the ad looks like this
– https://www.screencast.com/t/Fini7DHO0Z
With an added margin both top and bottom it would look like this
– https://www.screencast.com/t/ms1fZpD9jLa
.td-header-rec-wrap {
margin-top: 14px;
margin-bottom: 14px;
Enter that here – https://www.screencast.com/t/mt7A3PpdSKv
Do you maybe use a value here for tablets? – https://www.screencast.com/t/AUl3xVNYslL3
Thanks Simion, it is perfect now!!!
