Help me! I have got a problem. My menu is break.
It should be like that: http://oi64.tinypic.com/fax9cn.jpg
But, the menu change his position when I do scroll: http://oi64.tinypic.com/33dbevm.jpg
My website is informeinsolito.com
Hello rcallejonvillalobos,
I have checked your website and your mega menu feature seems to work as expected. http://screencast.com/t/axLsn4UWBVN I suspect it could be a problem that might be caused by the plugins in conflict. Please try to disable all the active plugins, except Visual Composer, clear all cache and install only the plugins that come bundled with our theme and rule our the conflicting plugins.
Thank you for the message!
