Problem About Updating Theme
Hi all,
i want to upgrade theme, but when i try to check preview, i see there is “hack” warning on screen. im using the old Newsmag theme right now.
My Website: http://www.gribilge.com
Preview screen im seeing: Theme problem
When i install first time this theme, i get same problem but fix, i dont remember how but with little change i think.
Preview screen im seeing: http://imgur.com/QGkjjZp
Please make sure that you’re using the folder downloaded from themeforest to update the theme, here it’ the update guide: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ Also deactivate all plugins clear all caches, switch to a default WP theme and test again. You can also try by doing a fresh install of WordPress, then try to install the theme and check if this warning persist.
If you still can’t manage to solve this issue please address us us via email at contact@tagdiv.com including a link to this conversation and also give us wp-access so we can have a closer look at this and we will get back to you as soon as possible.
my problem solved, thank you tagDiv!
