after installing Revolution Slider I get the following message trying to activate it:
Revolution Slider Error:no update action taken!
or on other occasions I got a longer message about a fatal error. I tried deleting it and uploading it from the zip that came with the theme, but still getting the same error messages. So far I could not activate the plugin.
Thanks for your help!
Another plugin that you already have installed and active could interact with it. Have you tried this without any plugins activate? Also please make sure you download and use the latest theme version and that rev slider plugin within the theme files from plugins folder.
Try this without the plugins and also make sure you empty cache and purge files if you use cache and/or any CDN host services and let me know how it goes.
Seems that others have reported this issue also when trying to use the plugin on a SQL database.
Please address this to plugin’s support also: http://codecanyon.net/item/slider-revolution-responsive-wordpress-plugin/2751380/comments?page=25
Hope this helps!
