Problem activating template
I need help ASAP. I’ve installed Newspaper 8.7, the installation went fine(i think) but now i can’t activate the template and also can’t activate any one of the available demos.
In the Activation page, i can see the activation button, but when i press it nothing happens. About the demos, the problem is exactly the same, i click on the install button and nothing happens.
Please tell me what i need to do to solve this problem.
Thank you
Problem solved. Thank you.
