problem after update
Hi I did the update last Sunday, after the update I had this problem, when I create a new post I don’t get the preview and this error.
I disabled all plugins but nothing anyone knows how to shine thanks.
Fatal error: Uncaught Error: Call to a member function format() on boolean in /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/state/single/tdb_state_single.php:1667 Stack trace: #0 /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/wp_templates/tdb_view_single.php(88): tdb_state_single->{closure}() #1 /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/wp_templates/tdb_view_single.php(88): Closure->__invoke() #2 /home/kendymak/offerteday.com/wp-includes/template-loader.php(98): include(‘/home/kendymak/…’) #3 /home/kendymak/offerteday.com/wp-blog-header.php(19): require_once(‘/home/kendymak/…’) #4 /home/kendymak/offerteday.com/index.php(17): require(‘/home/kendymak/…’) #5 {main} thrown in /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/state/single/tdb_state_single.php on line 1667
Please make sure that you have the latest version of Newspaper them v10.2 and WordPress 5.3
Please de-activate the schema articles from here: https://www.screencast.com/t/0E3IucACC You will have to check that in order to deactivate the schema, this issue will be fixed in the next update.
Let me know the results!
ok thanks at the moment i solved this problem thanks to his guide. I have another less serious problem if you can give me a hand also on this I will be grateful.
I await instruction and excellent service
Warning: number_format() expects parameter 1 to be float, string given in /home/kendymak/offerteday.com/wp-content/plugins/td-social-counter/shortcode/td_block_social_counter.php on line 175
I think that you do not set well some parameters ( numbers) in social counter, please check if you have set some fix counters to be set right -> https://i.imgur.com/IYYpdx1.jpg
If this is not the problem, then please provide some more details and some screenshots or a link where I can check this problem.
hi I had a problem after the update made yesterday, I went from version 10.2 to version 10.3 it is a problem that can be solved otherwise I go back to version 10.2 I await
Fatal error: Uncaught Error: Call to a member function format() on boolean in /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/state/single/tdb_state_single.php:777 Stack trace: #0 /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/shortcodes/single/tdb_single_date.php(130): tdb_state_single->{closure}() #1 /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/shortcodes/single/tdb_single_date.php(130): Closure->__invoke() #2 /home/kendymak/offerteday.com/wp-content/plugins/td-composer/legacy/common/wp_booster/td_global_blocks.php(27): tdb_single_date->render(Array, ”) #3 /home/kendymak/offerteday.com/wp-includes/shortcodes.php(325): td_global_blocks::proxy_function(Array, ”, ‘tdb_single_date’) #4 [internal function]: do_shortcode_tag(Array) #5 /home/kendymak/offerteday.com/wp-includes/shortcodes.php(199): preg_replace_callback(‘/\\[(\\[?)(tdb_si…’, ‘do_shortcode_ta…’, ‘[tdb_single_aut…’) #6 /home/kendymak/offerteday.com/wp-content/plugins/td-composer/includes/tdc_compos in /home/kendymak/offerteday.com/wp-content/plugins/td-cloud-library/state/single/tdb_state_single.php on line 777
If you want to can try the the update on a staging website were to set a copy of your actual website and updated it via FTP, if there are some problems, let us know and we’ll try to solved theme as soon as possible!
