Hello, after update im have problem:
1 – not working “edit with tag div compresor”: https://b.radikal.ru/b31/2105/fe/7ba79e7f5fde.jpg
2 – mobil version dont see information in post (he like clear), but descktop see that: https://a.radikal.ru/a40/2105/49/01125ab5d989.jpg
3 – have error on top: https://b.radikal.ru/b03/2105/d6/0c101a910ae2.jpg
Please start looking for a plugin conflict, deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
I want to say thank you!
1.It was a plugin conflict (weird because these are your plugins). I disabled tagDiv Mobile Theme – the mobile version is working.
2.tagDiv Composer started working well when I removed the caching plugin files (hosting leftovers).
3.Your support team has updated the template and subordinated Instagram.
Strength and patience in your work!
