Problem after updating WordPress
I have updated my WordPress and images on my site had been disappeared, the problem was solved by adding —img {
opacity: 1 !important;
}— in my css. But now I have another problem: my media slider is not working, plus Visual Composer has stopped: ajax is not working, filters…
Here is my website blog.pandokyerevan.com.
Need help!!!!
After WordPress updated at V 4.5 there appeared a jQuery conflict in our theme. We fixed this conflict and the current theme version available on themeforest works fine, also we included last version of Visual Composer plugin.
Try to update the theme at V 2.3.6, and Visual Composer at V 4.11.2 following our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ – https://forum.tagdiv.com/newsmag-how-to-update-visual-composer-plugin/ deactivate all other plugins, clear all caches and test again.
Not sure if it has to do with the WP update but Visual Composer wont let me make a new page and add its settings. I am trying to add in the YouTube video player so when I click on the link to add the YouTube player nothing happens. The title of the icon turns black but that is all.
WP v: 4.5.1
Visual Composer v: 4.11.2
Try to deactivate all plugins except Visual Composer, clear all caches, purge cdn files if you’re using then test again. If you still can’t manage to solve this please provide your site url so I can have a closer look.
Hi, I have the same problem with the images on my site (http://www.bouger-voyager.com/). I have just installed the last version of the theme 2.3.7 with the last version of the Visual Composer plugin but the problem is always there and the images don’t appear. Can you help me please ?
I’ve checked your site and images are displayed fine now: http://screencast.com/t/Chq4r4BtMGv
If you still need assistance on this please provide more detail about your issue and we will get back to you in shortest time possible.
No it doesn’t work on Firefox, but I have just tried on Google chrome and it works, it’s true. But the problem is still here with Firefox !
I’m having the same issue with images. They’re all not showing. My site isn’t live yet. Still trying to fix all these issues. I really need my site working ASAP so I can launch it later this month.
All work for me, I don’t know why it doesn’t work yesterday on Firefox but tomorrow it’s OK 🙂 thanks
@Mikarmano
the theme is tested and works fine whit all browsers specified on themeforest: http://screencast.com/t/Nq1iN73V I am not sure why that happened on your site but it could be a problem cause by cache. If this happens again try to clear the cache then test again.
@thejourno
make sure you update the theme according with our documentation: https://forum.tagdiv.com/newsmag-how-to-update-the-theme/ deactivate all other plugins except Visual Composer, clear all caches then test again.
