Problem Alloweb Memory
Hello everybody,
I have again a problem with memory size when i go to edit a page in my site.
The memory limit is in 256 and it was working until now.
This is the message of the error:
Fatal error: Allowed memory size of 268435456 bytes exhausted (tried to allocate 16384 bytes) in /homepages/18/d733391872/htdocs/clickandbuilds/DeportesAvila/wp-includes/wp-db.php on line 2007
Also, TD composer doesn’t work neither. It is allways charging.
Can you help me?
We recommend the 256 MB to your memory limit but maybe, you have some plugins which consume more memory and you need more than this value and then you need to increase it from your CPanel.
Hello again,
I change memory_limit to 512 (Later to 1024) and unactive all the plugins, but i have the same problem when i try to edit the index page.
Now i read that: Fatal error: Out of memory (allocated 887201792) (tried to allocate 241664 bytes) in /homepages/18/d733391872/htdocs/clickandbuilds/DeportesAvila/wp-includes/wp-db.php on line 1972
Thank you
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer your setup page. Also, provide your CPanel access.
Ok I send a mail.
Also remember that you need to change the memory setting in
BOTH:
a) server settings, memory allocated to php
b) in your wp-config file, to expressly specify memory amount
