Problem article paragraphs
with newspaper 6.2 I use article inline ad after 3 paragraph.
The problem is that the following paragraphs are united and no longer have the blank line.
It happens by moving the banner after 4 paragraphs…
In code it seem to be </p> instead of <p>
With previous versions there was the problem
How to solve?
Not sure what you mean as I’ve tested the art inline ads and are working fine. Could you please provide a link to one of your posts so I can inspect it.
Hi Lucian,
Version 6.2 also gave other problems
I went back to 6.1.
however, the problem was this
articlesarticlesarticlesarticles
AD300X250articlesarticlesarticles
MISSING THIS SPACE
instead of space the two paragraphs were merged
  • This reply was modified 11 years by Bintmusic.
I also tested this and I could not recreate your issue if you will have this issue in future please provide a link so we can inspect this – http://screencast.com/t/cJhUPfbICYshttp://screencast.com/t/4stlnwLRpzw
