Problem at Feed Validator
we have a problem with the RSS. The feed validator there generates a series of errors.
Look here-> http://validator.w3.org/feed/check.cgi?url=http%3A%2F%2Foverpress.it%2Fargomenti%2Ftech%2Ffeed
You have solved these problems with the latest update?
  • This topic was modified 11 years by OverPress.
The feed system is managed by WordPress not by the theme so it may be a problem related with WordPress functionality in this regard. You can try this with a default theme and check if this errors are still there.
We tried with the default theme and shows the same errors….
