Hello
Ich kann im Tagdiv Composer keine Templates in meine Seite laden. Wenn ich ein Header Template laden will, wähle ich eines auf der Templateseite aus und klicke auf importieren. Die Auswahlbox Importieren Ja oder Nein erscheint jedoch nicht und ich kann den Import nicht bestätigen. Können Sie mir weiterhelfen?
Greetings
Michel
Hello Anamaria
Thank you for your quick reply. I will try to describe the problem in more detail. I am working with the latest version of Newspaper, which is 12.1.1.
As I said, the problem occurs when trying to import a template. The checkbox “Do you want to import – Yes/No” is behind the window with the templates. When I close the window with the templates, the selection box appears for 2 seconds and is then gone again. And since you can’t move the window with the templates, you have no chance to get to the selection box.
I can also give you access to the backend, so you can have a look at the problem yourself.
Best regards
Michel
Translated with http://www.DeepL.com/Translator (free version)
Hello Michel!
Contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cpanel url and credentials
We will help you as soon as possible!
