Problem between Facebook plugin and SEO WordPress plugin
I have installed plugins and there is a problem between 2, Facebook plugin (to put a facebook comment) and Yoast WordPress SEO. At the beginning, 2 plugins work very well together. But now, the facebook comments doesn’t appear at bottom of pages articles. And sometimes, the SEO plugin turns off. I don’t know why it happens. Can you help me please?
My website : http://www.bougerweb.com
Example of articles : http://www.bougerweb.com/hot-dudes-reading-des-mecs-et-des-livres/
Unfortunately we did not tested Facebook plugin with the Newspaper, so I can’t provide you a solution for this.
Try to disable all plugin and leave only Visual Composer and this 2 plugins active if you say that those 2 plugins worked well together, maybe is a conflict with another plugin. Also empty your cache.
