I have issues with using the block quote formats. I’m trying to change the Box Quote Center and Pull Quote Center it works fine on the website but it doesn’t show properly when it comes to Facebook Instant Article. While, if I use the default blockquote it shows fine.
My question is does the format box quote and pull quote not applicable for Instant Article? or if not, is there any way to change the design / look of the default Block quote? Thank you
Unfortunately we cannot say for sure as we have not tested instant articles with our theme. The plugin is not among the tested and recommended plugins. Sorry for the inconvenience. The quote styles from our theme could not be applicable for instant articles.
You can change the design of the default blockquote if you have a bit of css knowledge.
You cna use this class to target the quotes:
.td-post-content blockquote p{ your css code here }
