Problem charging TD composer
Hi, when i try to enter at TD Composer Editor i have this problem on console:
Uncaught ReferenceError: $r is not defined at <anonymous>:1:1
and http error 500,
can you help me please? i don’t know what to do…:S
Something must be different there if you use the same theme and exactly the same plugins, but there is an error.
Does it happen if you switch to a default theme? Could also be server related if you have different hosting.
Maybe contact the plugin author as well, they might have an idea about the problem. Or search for similar issues with the plugin, online. I have no experience with the addons, unfortunately.
