I followed this:
The headers are in the wp-content\plugins\td-composer\legacy\Newspaper\parts\header folder.
Create the same folder structure under your child theme root path (…\child_theme_name\parts\header\), copy the header file you need to modify there, and it’s ready to be used.
and it not worked for “td-login-modal.php”
Best Regards
Please notice that if you want to set the td-login-modal.php in child theme you’ll need to set the top bar that you are using to, for example I have set top bar style 1 -> http://prntscr.com/p0l1qj also make sure that you set the path in child files like this
wp-content/plugins/td-composer/legacy/Newspaper/parts/header/
or copy those file in parts/header too.
