Problem CLS
Since July, we’ve had an issue with our website that we can’t resolve. Our CLS, measured with PageSpeed ​​Insights, is greater than or equal to 0.30 on mobile. We can’t figure out what’s causing this high CLS. For example, on the desktop side, we have a CLS of 0.002. The problem only affects mobile, and since this issue began, the site hasn’t met Google’s requirements, preventing our articles from being published on Goolge Discover (before, when we met all the mobile requirements, we were always on Goolge Discover).
Our magazine is this: http://www.moviemag.it
Can you check and tell us how to fix the problem?
Thanks for your help.
See this screenshot https://ibb.co/M5KM0LV2
I just checked the metrics and the CLS for mobile is 0 – https://i.imgur.com/LhWPca0.png, so this will be updated on time when you’ll have ebnought real user data – https://i.imgur.com/UV6jQQI.png
Hi Calin,
The CLS you measured is for the homepage http://www.moviemag.it, while the CLS score at the top (0.3) refers to the site’s articles. For example:
https://www.moviemag.it/sleeping-dogs-russell-crowe-come-non-lo-avete-mai-visto/
https://www.moviemag.it/identita-violate-trama-recensione-cast/
https://www.moviemag.it/homo-argentum-il-nuovo-film-di-mariano-cohn-e-gaston-duprat/
If you try running the test on these example URLs, you’ll see that the CLS is higher than 0.3, and I don’t understand why.
Anyway, can we continue the discussion via your service email address to check the site? I’ll provide you with the administrative credentials and the cPanel login if you agree.
Yes, we can continue via email.
I just checked the mentioned links and the metrics are ok – https://i.imgur.com/4EqXULg.png – https://i.imgur.com/yJbPr4o.png
https://i.imgur.com/khoM8L9.png – https://i.imgur.com/FEsxNTO.png
https://i.imgur.com/UdPm5Pq.png – https://i.imgur.com/Rw6ONt1.png
Now the CLS in CWV will be updated in time, but as long the metrics are green when the CWV is updated, the CLS should have a smaller CLS under 0.3
Hi Calin,
Can you tell me the email address where I can write to you? I need support with other issues.
  • This reply was modified 1 year by Alex.
Hi Alex, you can contact us via email at contact@tagdiv.com
