Problem Color in Menu
When the page is loading, the background color of the bar is black.
When finish loading the page, the color is correct (blue). How do I avoid that effect?
I have Fast News Demo install.
https://www.screencast.com/t/MghdgViX1EtG
I make some test, but I can not recreate this problem -> https://www.screencast.com/t/w6UHN547UUT
But if this is a problem for you, then you’ll need to edit the demo file and set there the header color gradient, you need to go in Newspaper>includes>demos>fast>demo_style.css
on line 15
https://www.screencast.com/t/IbKm1xAoc3h
https://www.screencast.com/t/GYqLtetMzTp
Because first time is load the style from the theme files and after that will be load the one from theme panel, also please make sure that you clear all cache after you do those changes.
Thank you for the understanding.
