Problem creating and/or editing a footer
I have added a new cloud template and selected the footer category. From that I pick one that I like, and tweak it to my liking. After saving and using it on a page, it appears like there is some top margin that I need to delete. Returning to the cloud templates page, I notice that the for the footers (all of the footers) there is no option to edit via the Tag Div Composer, unlike all other templates in the same page. Additionally, when I create a new template, in an attempt to make this right the first time round this time – because only the first time you import the footer template is it possible to edit it in the tag div composer (I don’t know why, it doesn’t make any sense…) – sometimes I get an error like the following when I try to rename it to something that will make sense:
Invalid template type! Please make sure your are editing a supported template type title.
The above message is returned after I have attempted to edit a supported template I have imported into tag div composer from its own cloud templates library.
Please assist me with this. Thank you.
Please check this video: https://www.screencast.com/t/fGV2uwNO2I
You can assign and import from Website Manager which footer template you need.
If you have a cloud/PRO template, but you can’t edit the footer, then edit your homepage with TagDiv Composer, scroll till footer, click on footer zone and you can edit/delete the elements there.(see the video)
