Problem Displaying Subcategories In Mega Menus
I’m having a problem with mega menus. I create categories and make a menu with them. Then I make sub-categories and put them inside my category mega menu but the links to them are showing at the bottom of the mega menus instead of to the left like in the demo. Here is a screenshot of my problem: http://screencast.com/t/u2fPTQ84T
As you can see it is correct in the demo but my sub-links are showing up at the bottom rather than to the left. I want them on the left like in the demo.
You will need to make sure those subcategories are set as subcategories of an category, like this: http://screencast.com/t/Uo5fM2ZhVzeq
Then go to appearance > menu and add that category to your menu then make it a mega menu, should look like this: http://screencast.com/t/vlrptTLg91
Hope this helps!
